The Organization dialog box
Command
Path
View bar
Shortcut
Organization
Tools
Ctrl+Shift+O (Windows)
Cmd+Shift+O (Mac)
Create and manage structural elements of the drawing using the Organization dialog box. This dialog box has specialized functions to sort, select, and edit its list items; see List box functionality.
To use the Organization dialog box:
Select the command or click the View bar button.
Alternatively, select Edit View from the Saved Views menu on the View bar.
The Organization dialog box opens.
Select the appropriate tab for the element to be created or edited.
From the top of the dialog box, select either Details or Visibilities view.
Generally, the Details view shows the current settings for each element, and enables editing of layer and class visibilities in the drawing area; the Visibilities view enables editing of layer and class visibilities in viewports and in saved views (see Columnas de visibilidad).
Buttons at the bottom of each tab provide creation and management functions. Alternatively, right-click on a list item to display a context menu, which has most of the same functions as the tab buttons.
Classes tab
If a description is entered for the class, it displays in a screen tip when you position the cursor over the class name. On Windows, click the disclosure arrow on the screen tip to collapse or expand it.
Control
Function
Search box
Enter text to filter the list by name
Filter
Select a filter for the list
Manage Filters
(button only)
Opens a dialog box to add, edit, delete, or import filters for the class list; see Filtering and tagging classes and layers
New
(button and command)
Opens the New Class dialog box, for Creación de clases.
When a new class is created, it does not automatically become the active class.
To quickly add classes to a hierarchical structure, select an existing row at the desired level before creating a new class. The new class name uses the same prefix by default. For example, if the “Arch-Wall-Ext” class is selected when you create a class, Arch-Wall- is the default prefix.
Edit
Select a class and click Edit to edit the class in the Edit Class(es) dialog box. See Setting class properties. This option is not available when classes are displayed in hierarchical order and a class group header is selected.
Assign Tags
(command only)
Opens the Assign Tags dialog box, to add tags to or remove tags from this item. Use tags to sort the class list, and to define class and layer filters. See Assigning tags.
Duplicate
Select a class and click Duplicate to create a copy of it. The name of the duplicate is the same as the original class, with a number added (for example, cabinets 2); if the original name ends in a number, the next available sequential number is used. This option is not available when classes are displayed in hierarchical order and a class group header is selected. Any tags assigned to the class are duplicated as well.
Delete
Select a class and click Delete to open the Delete Class(es) dialog box. Specify what to do with the objects currently assigned to the class(es) being deleted (delete them, or reassign them to another selected class). All objects in the deleted class(es) are moved to the appropriate class or deleted, as specified. This option is not available when classes are displayed in hierarchical order and a class group header is selected.
Note that the Dimension and None classes cannot be deleted. These are default classes in every drawing.
Preview
(button only)
Displays a preview of the current settings in the drawing area
Class Tags List
(button only)
Opens the Default Class Tags List dialog box, for Creating default tag lists of tags that will be available to assign from the Organization dialog box and Navigation palette. Enter the tag names, pressing Enter (Windows) or Return (Mac) to separate each item.
Select All
(command only)
Selects all classes
Hierarchical display mode
Click to toggle the hierarchical display of classes; additional options are available for controlling the hierarchical display at various levels, and for controlling visibility settings. See Presentación de clases en orden jerárquico.
Expand All
(command only)
When classes are displayed in hierarchical order, displays all classes in the file
Collapse All
(command only)
When classes are displayed in hierarchical order, collapses the list to display only top-level classes (those with no dash in the name) and class group headers
Design layers tab
The design layer name displays in italics if the layer is referenced; the name is blue if the layer is checked out from a shared project. If a description is entered for the design layer, it displays in a screen tip when you position the cursor over the layer name. If the layer is referenced, the screen tip also displays the full layer name and the source file name. On Windows, click the disclosure arrow on the screen tip to collapse or expand it.
Control
Function
Search box
Filter
Manage Filters
(button only)
Opens a dialog box to add, edit, delete, or import filters for the layer list; see Filtering and tagging classes and layers
New
Opens the New Design Layer dialog box. See Creación de capas.
When a new layer is created, it becomes the active layer.
Edit
Select a layer and click Edit to edit it in the Edit Design Layers dialog box. See Setting design layer properties.
Assign Tags
(command only)
Opens the Assign Tags dialog box, to add or remove tags from this item. Use tags to define class and layer filters. See Assigning tags.
Duplicate
Select a design layer and click Duplicate to create a copy of it. The name of the duplicate is the same as the original layer, with a number added (as in floorplan-2); if the original name ends in a number, the next available sequential number is used.
Delete
Select a design layer and click Delete; when prompted, click Yes to confirm the deletion. When a design layer is removed from the drawing, all objects in that layer are also removed.
Note that at least one design layer must remain in the drawing.
Preview
(button only)
Layer Tags List
(button only)
Opens the Default Layer Tags List dialog box, for Creating default tag lists of tags that will be available to assign from the Organization dialog box and Navigation palette. Enter the tag names, pressing Enter (Windows) or Return (Mac) to separate each item.
Page Setup
(button only)
Opens the Page Setup dialog box; see Page setup
Update Reference
(command only)
(Layer import referencing method only) Available if a design layer has been referenced into this file. Select a referenced layer and then select Update Reference to update this file with layer information from the master file. See Referencing features.
Check Out
(command only)
Available if this is a shared project. Select a layer and then select Check Out to check out the layer for editing. The layer name displays in blue when it is currently checked out. See Layers tab.
Release
(command only)
Available if this is a shared project. Select a layer and then select Release to release a checked out layer so that other project users can edit it. See Layers tab.
Administrative Release
(command only)
Available if this is a shared project, and you have administrative permission. Select a layer and then select Administrative Release to release a layer checked out by another user. See Layers tab.
Select All
(command only)
Selects all design layers
Arch.pngStories tab
In the Vectorworks Architect product, an additional Stories tab is available; see Setting up the building structure with stories.
Sheet layers tab
The sheet layer name displays in blue if the layer is checked out from a shared project. If a description is entered for the sheet layer, it displays in a screen tip when you position the cursor over the layer name. On Windows, click the disclosure arrow on the screen tip to collapse or expand it.
Control
Function
Search box
Filter
Manage Filters
(button only)
New
Opens the New Sheet Layer dialog box. See Creación de capas.
Edit
Select a sheet layer and click Edit to edit it in the Edit Sheet Layers dialog box. See Setting sheet layer properties.
Assign Tags
(command only)
Duplicate
Select a sheet layer and click Duplicate to create a copy of it. The Sheet Title of the duplicate is the same as the original layer. The Sheet Number of the duplicate is the same as the original layer, with a number added (as in details-2); if the original Sheet Number ends in a number, the next available sequential number is used.
Delete
Select a sheet layer and click Delete; when prompted, click Yes to confirm the deletion
Preview
(button only)
Layer Tags List
(button only)
Check Out
(command only)
Release
(command only)
(command only)
Select All
(command only)
Selects all sheet layers
Viewports tab
The viewport name displays in blue if it is checked out from a shared project.
Button / Command
Function
Search box
New
Opens the Create Viewport dialog box. For sheet layer viewports, see Creación de encuadres de lámina a partir de una capa de diseño. For design layer viewports (Vectorworks Design Suite required), see Creación de encuadres referenciados de capa de diseño.
Edit
Select a viewport and then select Edit to edit it in the Properties dialog box; see Viewport properties.
Duplicate
Select a viewport and click Duplicate to create a copy of it. The name of the duplicate is the same as the original viewport, with a number added (as in details-2); if the original name ends in a number, the next available sequential number is used.
The Drawing Title of the duplicate is the same as the original viewport. If the original viewport has a drawing label, the Drawing Number of the label in the duplicate viewport is the next available sequential number.
Vectorworks places the duplicate viewport directly on top of the original, in the original sheet layer.
Delete
Select a viewport and click Delete; when prompted, click Yes to confirm the deletion
Preview
(button only)
Check Out
(command only)
Available if this is a shared project. Select a viewport and then select Check Out to check out the viewport for editing. The viewport name displays in blue when it is currently checked out.
Release
(command only)
Available if this is a shared project. Select a viewport and then select Release to release a checked out viewport so that other project users can edit it.
(command only)
Available if this is a shared project, and you have administrative permission. Select a viewport and then select Administrative Release to release a viewport checked out by another user.
Select All
(command only)
Selects all viewports
Saved views tab
Button / Command
Function
Search box
New
Opens the Save View dialog box; see Creación de vistas guardadas
Edit
Select a saved view and click Edit to edit it in the Edit Saved View dialog box; see Edición de vistas guardadas
Duplicate
Select a saved view and click Duplicate to create a copy of it. The name of the duplicate is the same as the original view, with a number added (as in deckview-2); if the original name ends in a number, the next available sequential number is used.
Delete
Select a saved view and click Delete; when prompted, click Yes to confirm the deletion
Select All
(command only)
Selects all saved views
References tab
Button / Command
Function
New
Opens the Open File dialog box. For layer import references, see Cómo agregar y editar archivos de referencia. For design layer viewport references (Vectorworks Design Suite required), see Creación de encuadres referenciados de capa de diseño.
Edit
Select a referenced file and click Edit to open the Edit Reference dialog box. For layer import references, see Cómo agregar y editar archivos de referencia. For design layer viewport references (Vectorworks Design Suite required), see Creación de encuadres referenciados de capa de diseño.
Delete
Select a referenced file and click Delete. In the Delete Reference dialog box, specify what to do with the items in the file that are currently referenced. See Eliminación de referencias.
Update
Select a referenced file and click Update to update this file with information from the master file. See Updating references.
Settings
(button only)
Opens the Reference Settings dialog box; see Setting the referencing options
Select All
(command only)
Selects all references
Organización del dibujo
Concepto: generalidades de capas
Concepto: generalidades de clases
Saved views
Workgroups and referencing
Project sharing
